C2 Bolt Heads - Different markings on each side - NCRS Discussion Boards
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11302
    Today I was going through some bags of old parts. It appears this helps prove that on the factory floor the workers had bins on each side and the bins were filled with bolts from various vendors and different from the other side.
    So when the vendors hear about this they're going to have to start mixing heads in the bags of bolts.
    examples.... I'm not sure what year they all came from. Maybe some from my 63 too.
    Fuel tank strap hardware... RSC & RBW
    Body Bolt... UR & RSC
    Lower front shock absorber... various. Also note 1 serrated washer underside.
    Splash Shield... Anchor & L
    WB and "circle"
    I'll add more here as I find them.
    Rich
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11302
    Re: C2 Bolt Heads - Different markings on each side
    More....
    Not sure if shocks or not. Bag markings worn off.
    2 RBW & 2 E in a circle. Came from same car but 2 lengths.
    Headlight bucket .. All B&H. Never saw other markings in my times but may be others.
    SB Exh manifold 3 M & 1 Circle
    Lower rear control arm to frame. These same for each side, just interesting. M has regular nut, AP has a lock nut. Different lengths too.
