What a day. I was able to get a nice used temp sender for my '72 L48 and got it installed and reading well yesterday. I'll finish that thread up soon.
Now my next problem/challenge - all of a sudden, after test driving it to confirm temp sender is working and accurate, the car won't start.
Here's what I have:
I turn the key and I get one click, then nothing. Courtesy lights go out, key buzzer quits, nothing electrical works. I wiggle and re-tighten the battery connections. Same thing, over and over. It'll click once then dead, until I repeat the wiggle/tighten process and try again.
I remove the battery and run jumper cables from the battery to the positive and negative cables in the car. I get the "rattling" noise like any time a battery is weak. (Battery is new and tests 12+ volts). It does this each time I turn the key.
I check the (-) connection to the frame. Good. I check the (+) connection to the starter solenoid. Good.
I tapped on the solenoid and the starter case with a small hammer, in case one of them was in a dead spot (?). Fail.
I hook up a fully charged booster instead of battery. Turn the key. Same rattling noise but no start.
Bumped the car in 3rd gear to move the flywheel in case bendix is stuck in the flywheel. Nope - same as before.
Very frustrating. Any ideas appreciated. Please!
Here's what I have:
