C2 Horn Button - NCRS Discussion Boards
C2 Horn Button
  • Tim T.
    • December 9, 2009
    • 141
    C2 Horn Button
    What is the difference between a 66 and a 67 horn button if any ?
    Thanks in advance.
    Tim
  • Leif A.
    • August 31, 1997
    • 3607
    Re: C2 Horn Button
    Tim,
    '65-'66 are the same. '67 slightly different. Look at the picture below...'65-'66 lower, '67 installed on my '67. Notice the outside edge of the two. The '65-'66 is narrower, more sharply defined. The '67 has a more rounded, wider appearance.
    Leif
    • Tim T.
      • December 9, 2009
      • 141
      Re: C2 Horn Button
      Leif,
      Thanks, that is a good comparison.
      Tim
      • Ara G.
        • January 31, 2008
        • 1108
        Re: C2 Horn Button
        Originally posted by Leif Anderson (29632)
        Tim,
        Leif,
        Also, from memory, the height of the actual cap is taller on the 65/66 cap than the 67 cap. Meaning looking from the side, the 67 cap is thinner/shorter than the 65/66 cap. ARA
        • Leif A.
          • August 31, 1997
          • 3607
          Re: C2 Horn Button
          Originally posted by Ara Gechijian (48542)
          Leif,
          Ara,
          You are correct, as well...minor difference in height. Of course, I learned all this from you back in 2015 at the Lone Star Regional when you judged my interior.
          Be well, my friend
          Leif
