1967 Horn Relay - NCRS Discussion Boards
1967 Horn Relay
  • Mike H.
    • February 1, 1980
    • 45
    1967 Horn Relay
    I have a 1967 Air Conditioned car. What terminal on the horn relay does the red wire with the 20 Amp fuse for the air conditioning go? Battery terminal with the bat. wire or the other term. with the black wire. Have two 67 Air cars both wired differently. Am confused. Have amp. gauge problems too. Thanks for the help. Mike Huffman
  • Leif A.
    • August 31, 1997
    • 3607
    Re: 1967 Horn Relay
    My '67 factory A/C car. In the pic below, the lower right lug is where the 30 amp fuse wire is attached along with the red/black wire with the fusible link. The solid black wire exiting the wiring harness is the ground.
    Leif
    • Mike H.
      • February 1, 1980
      • 45
      Re: 1967 Horn Relay
      Thank you Leif.
      CORDially Mike
