1966 L79 engine orange paint coverage; input solicited - NCRS Discussion Boards
  • Gary B.
    • February 1, 1997
    • 6979
    Engine block, freeze plugs, water jacket plugs
    Heads
    Oil pan, gaskets, bolts, and drain plug
    Lower alternator bracket
    Harmonic balancer, except central, pulley contact area; little paint on back side, except lower portion
    Three to four inches on forward end of bell housing, including block attachment bolts
    Three to four inches on forward end of clutch fork
    Water pump bypass hose and clamps
    Clutch inspection shield and bolts
    Timing chain cover, gaskets and bolts, where not shielded by the water pump or harmonic balancer
    Front, back, and side edges of AL intake manifold where not protected by mask; orange overspray then covered by dull aluminum paint
    Water pump and 3 of 4 attaching bolts; water pump/alternator brace bolt not painted; inaccessible back side of pump has no paint; water pump hub not painted; some paint on water pump shaft?
    Some overspray on distributor hold down clamp
    No paint
    Engine pad was masked, no paint
    Clutch fork boot was installed at St. Louis, no paint
    Fuel pump mounting plate, no paint
    To those who have been thru the painting and judging process, I would love your input on what I might have missed.
    Gary
