C2 A/C duct repair - NCRS Discussion Boards
C2 A/C duct repair
  • John P.
    • August 31, 2002
    • 215
    C2 A/C duct repair
    I am looking for suggestions on repair of the driver side duct on my 1965 factory air convertible.
    i Would like a functional repair that doesn't stick out like a sore thumb, but reasonably simple.
    it seems that finding a comparable bit of black plastic might work- not sure how to source that.
  • Harry S.
    • July 31, 2002
    • 5258
    Re: C2 A/C duct repair
    The plastic is thinner than non-A/C ducts. Here is a broken one on eBay, make an offer....
    Make a thin cardboard piece to fit the hole, trace it onto the plastic part, Dremel it out and superglue it in. It's like working with egg shells.
    • Domenic T.
      • January 29, 2010
      • 2452
      John,
      medium glass cloth and JB weld after cleaning with acetone or equilivent.
      Dom
      • John P.
        • August 31, 2002
        • 215
        Can that be painted easily?
        • Domenic T.
          • January 29, 2010
          • 2452
          John,
          Yes, it will paint easy. You just have to color match. I have used fillers to hide the repair also.
          Dom
            • December 1, 2005
            • 173
            John,
            You might try Q-Bond Ultra Strong Adhesive produced by K Tool International. Would suggest you get some plastic as Harry noted and use this adhesive. You can get the adhesive from Amazon. I've used it with good results.
