C1 Grab Bar Clutch Head Scew - Size? - NCRS Discussion Boards
  • Peter M.
    • February 1, 1984
    • 361
    Re a 61 - I need to remove the 4 clutch head screws holding the passenger grab bar - can you please tell me what size clutch bit is required to remove those large clutch head screws! Thank you!
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11302
    Re: C1 Grab Bar Clutch Head Screw - Size?
    Peter I'm away and can't check my tool box but in a pinch try using a good heavy duty #2 flat blade screwdriver to remove them.
    Even better if its a Snap-On with the base of the shaft you can put a wrench on for extra torque.
    Rich
      • 15573
      Pete
      You will have a use for a variety of sizes on your 1961. Why not seize the opportunity to expand your tool collection. It will stand you in good stead for the future.
      https://www.amazon.com/CTA-Tools-875.../dp/B007RKOBOM
      I am sure these are not as good as Snap-on, almost nothing is, but in a pinch these will work more than once.
      • Peter M.
        • February 1, 1984
        • 361
        Perfect - thanks all - just ordered via the link - most appreciated!
          • 15573
          Never miss a chance to expand the tool collection.
