73 L48 fuel pump pressure - NCRS Discussion Boards
  • Douglas C.
    • August 31, 1990
    • 379
    I always thought correct fuel pressure for a stock Qjet was around 5.5 psi. I checked the AMA Specs and it states 7.5 - 9.00 psi (shut off pressure - 1800 rpm at pump outlet). I hooked a gauge to my fuel line that connects to the carb. Cranking engine it read 7.5 psi. So, does this all sound correct, with original fuel pump.
    Tks. Doug
