65 Coupe vent window weatherstrip - NCRS Discussion Boards
  • Dave K.
    • November 1, 1999
    • 951
    I am unhappy with the fit of the Corvette Rubber repro vent window W/S as is a lot of other guys. I had to trim the replacement rubber, applied silicone lubricant and closed the window as tight as possible to get the rubber to take a set. The current replacement rubber is thicker than the OEM and the Corvette Rubber repro of ten years ago. The replacement that I bought from CR 10 years ago for my 66 convertible was fine.
    Has anyone figured this issue out?
    Dave K.
  • Dan B.
    • July 13, 2011
    • 545
    Re: 65 Coupe vent window weatherstrip
    Dave, I'd suggest you contact them directly and ask them. I replaced my Coupe weather-stripping over 10 years ago with CRC and they fit perfect. No trim whatsoever needed. I can't imagine why they would change anything.
