Am in the process of replacing the rear pinion seal on my 67.
The drive shaft is removed. The rear leaf spring bolts at the TA have been removed and the spring is free. The rear cushion(aka snubber) has been removed. BUT, I cannot get the snubber bracket bolts removed. I do not want to drill a hole in the storage compartment.
How do I get the differential to rotate down so that the bracket front bolt can be removed?
Yes, I did put a 3/4" wood block above the differential and it is still in place.
I replaced the snubber cushion about 15 years ago and I do not recall getting the bracket off was this difficult.
