67 big block hood - NCRS Discussion Boards
67 big block hood
  • Fred M.
    Infrequent User
    • October 9, 2022
    • 3
    67 big block hood
    Recently purchased a hood top panel 67 big block hood and started looking for a lower frame. Found a new one online at "corvette image". Was wondering if anyone has ever done this and what the results were? Thanks. Fred Miller
  • Paul Y.
    • September 30, 1982
    • 570
    Re: 67 big block hood
    I have done it a couple of times. You will need to attach and adjust the frame to your auto and get it lined up and functioning properly. Then prep the adjoining upper skin and hood frame to accept the bonding adhesive. Check for proper height and shim as needed. Protect the body from adhesive squeezing out by applying masking paper or card board around the perimeter. Apply the ( I use Vette Panel Adhesive) bonding material and put weight on the hood over night or a day or two. Block sand the edges of the hood to get square and prime and paint. If you screw up you can always do it over. It is like working on a big model car.
    It's a good life!
    • Fred M.
      Infrequent User
      • October 9, 2022
      • 3
      Thanks Paul,
      What did you use for inner frame? I found only one for the big block hood but they want $829.00 for it. I have a small block hood but hate to cut it up.
