AGM Battery - NCRS Discussion Boards
AGM Battery
  • Jimmy G.
    • November 1, 1979
    • 975
    AGM Battery
    AGM versus conventional battery Car driven very infrequently. How long do you think is a good battery life?? Second part Once dead and recharged - would you trust it ??
  • Gene T.
    • May 31, 1997
    • 78
    Re: AGM Battery
    I prefer conventional batteries. When I have a car that is driven infrequently; I use a trickle charger continuously. The last battery that I bought was a GM Delco and it came with a 36 month warranty with a non prorated status; that impressed me. Just my 2 cents !
    • Gary S.
      • July 31, 1992
      • 1628
      Re: AGM Battery
      I have a 1972 LT-1 that had a ten year old battery that would be stored from late November to mid-March and I never used a battery maintainer. It would crank for ten seconds only to fill the fuel bowls when coming out of hibernation. I would then charge it when I got it home.
      I replaced the battery only because it was cheaper than getting towed when and if the battery failed, which never happened. So my limit was 10 years. I also have no problem with a battery that has been inadvertently killed and recharged. My daughter has done that without any significant issue.
      • David H.
        • June 30, 2001
        • 1485
        Re: AGM Battery
        Year of your car?
        Some problems with AGM in C5. Battery placed over wiring harness and leaks resulted in damage to harness (required wiring bundle replacement).
        Dave
        • Michael H.
          • December 1, 1987
          • 724
          Re: AGM Battery
          [QUOTE=David Houlihan (36425);933512]Year of your car?
          Dave[/QUOTE)
          Dave,
          Never had a problem with a AGM battery in a C5, the batteries that leak like a lead acid battery will damage the computer and wiring under the battery in a C5.
          I would recommend a AGM battery but get a trickel charger that charges AGM's.
          Mike
          • Greg W.
            • February 26, 2015
            • 141
            Re: AGM Battery
            Jimmy, I have had a AGM battery in a C-2 from 2016 and only use a trickel charger every once in a while and it is still going strong, car driven less than 1000 miles from 2016. 2015 Z06 had original battery and was dropping in volts over the past winter so I replaced it on the safe side,car has 11000 miles. I guess it is a crap shoot.
            Greg
            • Ray G.
              • May 31, 1986
              • 1187
              Re: AGM Battery
              Hello;
              ACDELCO batteries are sealed calcium based.
              Many $s less than AGM.
              Don't lose many points in judging.
              my .02
              Ray
              I hope you dance
