Tool recommendations for rear bearing set up.
Don Harris
Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)Tags: None- Top
Re: Tool recommendations for rear bearing set up.
Don, a couple of thing. You will need a couple extra of the bearing/shim spacers that are about 2" in length.
Shims get interesting and expensive. Let me know which ones you want to keep in stock because I have a lot
and wish to share. For a small fee each and USPS.
The axle installer I have and recommend (dont know the brand) but his is my discription.
Better yet here is an ebay one. I have used it a lot and it does pull the axle thru the bearings nicely.
The tool for setting up the bearing shims can be made from a used axle. Just have a friend cut down the two bearing surface so the axle bearings just slide on the axle. Save a hundred bucks or so.
Scott Fogaley@sbcglobal.net- Top
Thanks Scott. I have some shims, but will definitely get in contact if I need any more.Don, a couple of thing. You will need a couple extra of the bearing/shim spacers that are about 2" in length.
DonDon Harris
Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)- Top
Don - I have a bearing set-up tool if you would like to use it.- Top
Appreciate the offer Pat, but my friend is already planning to buy one. I normally use the Chapter owned set of tools or borrow Page's but we are doing a couple of cars and I don't know the full time frame yet.
DonDon Harris
