1965 neutral safety switch powerglide - NCRS Discussion Boards
  • Paul S.
    • June 30, 1982
    • 354
    On an automatic what 2 wires can i short across to by pass the neural safety switch to get the car to crank.? Or is there a way to test the switch to see if its bad ? Thanks
  • Bill C.
    • May 31, 1989
    • 424
    Paul, the safety switch simply connected at the purple wire to starter solenoid Male/Female connector usually lightly wrapped with friction tape in harness just above the wiper /washer motor. I do not know what you have left from switch harness, but if you simply plug the harness together ( as seen on a 4 speed car) it will bypass the switch, as the switch simply plugged in there, interupting the solenoid input. Then, be careful!
    • Paul S.
      • June 30, 1982
      • 354
      Thanks for the info
