C2 Power Window Motor Refurbishment - NCRS Discussion Boards
  • Milton S.
    Infrequent User
    • February 17, 2017
    • 4
    Does anyone provide a service to refurbish C2 power window motors? Do most of you do it yourself and are there kits/instructions available? From what I have read, the new replacement motors being sold run a bit faster and can be a bit problematic. i.e. causing problems/damage
  • Harry S.
    • July 31, 2002
    • 5258
    Milton, the P/W motor is similar but not identical to the wiper motor and the headlight motors. I suggest you contact one of the headlight motor restorers and see if they will rebuild you motors. I've used several of them over the years, they are all good. Check the Driveline Service Section.
