I just changed the oil in my 327 c.i./365 HP '65 roadster. Changed the filter as well. Added 6 quarts of oil.
Now, there is a small "puddle" of oil that collected on top of the intake manifold at the rear of the manifold that looks like it originated from the breather tube that is attached to the air cleaner. The "puddle" is very small, perhaps the size of a pencil eraser - but it should be there at all. The "puddle" is next to the edge of the intake where the intake bolt depressions are. If I wasn't so computer challenged I post a pic.
I only drove the car about 5 miles after changing the oil to ensure no leak from the filter canister or the drain plug. There is no oil leak evident at the back of the engine - bell housing,etc. Prior to this the engine had been leak free following a complete rebuild about 1500 miles ago.
I thought the "flow" on the breather tube was away from the air filter/carburetor, but this looks like the oil was pulled up into the air cleaner through the breather tube.
Any suggestion as to what would cause this to occur.
Could also be from distributor but I doubt it.
