Correct C2 convertible top staple? - NCRS Discussion Boards
  • Ian S.
    • June 30, 2002
    • 264
    Hello,
    What is the correct size and type of staple to use when installing a new convertible top on a '66 that would be factory correct?
    Thank you,
    Ian
  • Bob B.
    • March 1, 2003
    • 831
    Re: Correct C2 convertible top staple?
    Ian,
    Let me throw in a question on this, as well. It doesn't really matter since the staples aren't visible. However, since the tack strip is called a tack strip, I'm wondering if the factory used tacks? I have a piece of tack strip someone gave me that was supposed to have had the original top on it and it had tacks. So, what do the experts say?
    Bob
    • Kevin M.
      • November 1, 2000
      • 1271
      Your right never looked at when I had my car judged, kinda a like pistons. And tack strip a means to "fix to; attached " not a tack.
      KM
      • Wayne W.
        • April 30, 1982
        • 3605
        Originally posted by Ian Spanic (38270)
        Hello,
        Thank you,
        Ian
        The original staples were about 3/16 or so across the top, and they were fairly thin. I could dig up a picture somewhere, but as stated, they are not visible when assembled, even with the top back.
        • Ian S.
          • June 30, 2002
          • 264
          Wayne,
          If you could send a picture I would appreciate it.
          Ian
          • Wayne W.
            • April 30, 1982
            • 3605
            Wayne,
            Ian
            This is not a midyear, but it is the same staple.
              Plus, since the staples are hidden once they're installed, you might want to consider 'cheating' and using either SS or brass to thwart rust...
              • Bob B.
                • March 1, 2003
                • 831
                That is a good definition of tack, but for folks who have pulled apart an original top for the first time, did they find staples or tacks?
                • Kevin M.
                  • November 1, 2000
                  • 1271
                  Staples are used to attach the top material to the tack strip.
                  Now my Grandfather use to have the job installing interiors in model A's and T's. Still have his tack hammer, story went he put a hand full in his mouth and used the magnetic end to grab a tack and hammer it in.
                  Kevin
                  • Gerard F.
                    • June 30, 2004
                    • 3803
                    Ian,
                    I've read in a 1992 Restorer Article, that the OEM staple was 1/8" crown by 5/16" length.
                    However, when I did my C2 top, I used SS No. 4 (3/8" crown) by 3/8" length with a manual stapler for the top to tack strips, and galvanized 1/4" crown by 1/2" with an air stapler for going through multiple layers of material such as the wireon, front windlace, and rear straps to tack strip.
                    Jerry Fuccillo
                    • Ian S.
                      • June 30, 2002
                      • 264
                      Thank you all for you help!
                      Ian
