Are the power steering pump and pulley (3834720?)Corvette specific on my sb 72? Somehow the shaft gave out allowing for it move forward about 1/8", causing the pulley to stripout the wooddrift (sp)key and the notch in the pulley. Lucky for me I stopped the motor before any further damage, pulled the belt off and limped home without power steering. Both the pulley and shaft are damaged beyond repair. The rebuild kits that I've seen do not include the shaft, I thought that I might find something at my local you pull it?
Thanks in advance,
Kevin
Thanks in advance,
Kevin
