Adjusting hydraulic lifters - NCRS Discussion Boards
  • Bruce B.
    • May 31, 1996
    • 2930
    When adjusting lifters using the static method by adjusting certain valves at TDC and then others at 360 degrees from TDC ( zero clearance then tighten 1 turn) how critical is it that the timing mark be on zero?
    If off by 5 degrees can that be fatal to the engine.
    I just did my 250 HP FI 57 and it sounds great although I am sure I was off by a few degrees.
    Re: Adjusting hydraulic lifters
    Bruce-----
    I don't think that 5 degrees, or so, off the TDC mark will cause any problems, at all, with respect to hydraulic lifter static adjustment procedure.
