C2 glove box door alignment - NCRS Discussion Boards
  • Larry S.
    • March 11, 2007
    • 457
    I removed the glove box door on my '67 to paint it the correct sheen of black. It looks great, but when I re-installed it, I can see about one-half of two large screws that hold the glove box frame to the dash. (Hope that makes sense) I understand how to adjust the door left and right, but how do you adjust it upwards? Or is what I'm seeing normal? You can't see the two other large screws at the sides of the door. Thank you.
  • Mike M.
    Director Region V
    • August 31, 1994
    • 1463
    Re: C2 glove box door alignment
    Same method to adjust upward, if the door latches freely and securely, you're good to go.
    HaND
    • Stuart F.
      • August 31, 1996
      • 4676
      Sounds like your latch is adjusted out too far, if I understand you correctly. I don't know if my 63 is similar, but I don't see the screws around my door (no gap).
      Stu Fox
