I need a flywheel for my 1960 4sp 245hp and decided to go with a Hays 10-130 billet steel flywheel which is a 30lb 168 tooth, 14" flywheel that is drilled for both the 10.5" and 11" clutch. In other threads in the TDB it was stated that the 1960 model came with "a 28lb, 14", 168 tooth flywheel of GM casting #3729004" which has been discontinued.
I also read on the TDB that the aluminum bellhousing used in 1960 was meant for the 168 tooth flywheel with a 10.5" clutch disk.
After calling Hays, Summit, Luk and Paragon I am still not 100% sure if this flywheel and a 10.5" Luk clutch set (04-0421, which is what Paragon is likely selling) is a good choice for a stock feel clutch.
Does this make sense ?
