battery disconnect - NCRS Discussion Boards
battery disconnect
  • Sal R.
    • December 10, 2007
    • 160
    battery disconnect
    do I have to change my cable to install a diconnect pull switch .I have the spring cables now.1965 roadster 327
  • Stuart F.
    • August 31, 1996
    • 4676
    Re: battery disconnect
    Sal;
    I use a knife type battery disconnect switch with correct spring clamp cables on my 63. Works great. Probably not as pretty as the ones with the green knob, but it has worked well for over 25 years. Got mine from I believe "Lectric Limited" back in Chicago. I have heard some horror stories about the brand "X" knob switches; not making good contact, or not breaking contact well, that I'm glad i chose the knife type.
    Stu Fox
      Here's the Wirth knife-type disconnect switch on my '67 with the correct battery cables (I don't trust restoration batteries).
      • Stuart F.
        • August 31, 1996
        • 4676
        John;
        Looks just like mine except I do have a restoration battery. What ever works for you, no apologies necessary.
        BTW, thanks for putting me on to the "venting" consideration for my AFB percolation problem. Not solved yet, but think we're getting close.
        Regards;
        Stu Fox
