Well I thought I'd do a little prep work for the rear trailing arm swap.
Got the car jacked up in the yard (just can't move it from the place it was towed) and thought I'd pull the brake caliper to refinish it to go with the new trailing arm:
The caliper bolts came out just fine with a 5/8" spark plug socket, breaker bar with a pipe extender.
However, as soon as I pulled the caliper, the spindle fell to the ground. The brake caliper was the only thing holding the wheel in place. Here's what the spindle shaft looked like:
Here's the inside of the spindle support and the rest of the spindle shaft:
Found the half shafts, and U-joints with the spindle flange attached are just flopping around. However, the parking brake looks to be in good shape, just a little rusty.
Should be back on the road this weekend. I have my brake and alignment mechanic making a house call Friday to swap the broken trailing arm with a new one, so that I can move the car out of the yard. Then next week I'll bring it to his shop, and get the other side swapped and everything aligned correctly. Figuring on doing 1/2d Neg camber and 1/32" toe-in each side.
Did 67's use the cotter pins on the trailing arm shims. I don't see anyplace on the frame where the pins would go to hold them in place.
Feeling lucky, I thank my lucky stars.
