1960 Corvette: Any tips on the removal of the C1 power window Motor. Thanks DG
1960 Power window motor removal?
Re: 1960 Power window motor removal?
Drink 1 beer before you start and a second after you get the door pad and access plates off
Seriously they were a pain on my '58. I took mine out attached to the regulator. Be sure you remove the access plate from the aluminum vertical reinforcement piller in the door. Once you get the plate out they will come out as a unit. You can remove the motor without removing the regulator but you're working pretty blind and watch you fingers since the regulator is spring loaded.- Top
