C2 Drive shaft ? - NCRS Discussion Boards
C2 Drive shaft ?
  • M W.
    • July 31, 2001
    • 835
    C2 Drive shaft ?
    Hi all,
    Could someone tell me what year model car would use a drive shaft with a part # of 3868727 and what would be the correct number for a 64 327-300HP? All help is greatly appreciated.
    Craig
    Re: C2 Drive shaft ?
    That PN was used from 6/23/64 through at least the '67 model year on Corvette, Craig. For your '64 car, crack open the AIM and you ought to see the factory original PN that this replaced...
    • M W.
      • July 31, 2001
      • 835
      Thanks Jack I will.
        Remember that when dealing with driveshaft part numbers, the shafts in the P&A books are just the bare shaft, with no U-joints or yokes; the number in the Assembly Manual is the production shaft assembly, which included both U-joints and the front yoke.
