Re: Roller Cams
Who ever wrote this had a few good points but there's a little more to it than that.
First of all, the amount of energy consumed in frictional losses at the base of the lifters isn't anywhere near the amount of energy consumed by the oil pump so the theory that it's a trade off isn't even close to being accurate.
He mentions that oil goes into "sheer" at the lifter to cam lobe contact point. That's not exactly correct. Oil can/does go into "sheer" IF the viscosity is greater than necessary for a given load/speed. (often the exact cause of bearing failure in engines operated at high load/RPM before the oil is at/near operating temp)
Sheer is when the oil fillm is ripped apart at the friction surface.
A lot of folks still think that there's a lot of friction at the cam lobe/lifter but, as mentioned previously, if that were true, cams and lifters surely wouldn't last more than a few miles.
The writer does refer to the fact that there isn't actually metal to metal contact between the lifter and cam other than on rare occasions.
Here's the problem that most people don't consider when talking about frictional losses at the cam/lifter. With a flat tappet design, the load applied to the lifter is nearly straight up along the axis of the lifter bore. The contact area between the lobe and lifter moves across the face of the lifter as it is being raised in it's bore. Thus, very little frictional losses at the bore.
However, with a roller style lifter, the side loading applied at the lifter exceeds, by a great amount, the frictional losses of a flat tappet design at the cam/lifter contact area. This is because the contact point of lobe/roller is a lot closer to the C/L of the lifter body and the lobe is trying to push the lifter up AND to the side at the same time.
If you don't believe me, ask Clem how many roller lifters were destroyed because the sides of the lifter body were scuffed.
Either way, the frictional losses of either flat tapped or roller is nowhere near as great as that of the oil pump.
In previous discussions on this topic, I suggested that, to get some idea of the energy required to turn an oil pump at operating RPM, even at idle RPM, plug in your 3/8" electric drill and drive the pump in an engine on the stand. You quickly learn that it requires a LOT of energy to turn that pump, even at that slow speed. That's why most builders use a 1/2"drill.
Now imagine the amount of energy required to turn the pump at 2500 engine RPM. If you don't think this is a factor in fuel mileage/emissions, you need to think about it smore.
The boys in engineering didn't spent all that time/cash on this project just because they thought it would be cool to use roller lifters.
I still have a ton of GM engineering paperwork/documents on this subject and if I have time, (and can find it) I'll try to dig it out and post some of the info. Some pretty impressive numbers.
