I have the entire rear end unbolted as well as the cross member. I had assumed the entire rear end and cross member would drop out but the cross member stays solid after the outside two bolts are removed.
Is the cross member not removable with those 2 outward bolts?
If not, there are bolts that attach the cross member to the rear differential towards the center of the cross member, but they look almost impossible to get to.
Am I missing something in removing the cross member or are my only options to somehow remove the differential from the cross member with the center bolts?
You can make this a little easier by soaking the bushings in penetrating oil for a day or so.
