body off in a two car garage -- feasible?
Re: body off in a two car garage -- feasible?
Ian:
I'm in a similar situation with a 2-car garage and have thought about one of those PODs...renting it for the period I need until ready to marry body and chassis.
Also comtemplating raising body up and storing on jacks (house) with ability to roll chassis in and out from under body. Obviously, I'm exploring all options.Tom Russo
78 SA NCRS 5 Star Bowtie78 Pace Car L82 M2100 MY/TR/Conv- Top
Tom - the TDB is the Technical Discussion Board.
here is the link to the posting that shows a ceiling opening.
https://www.forums.ncrs.org/showthre...rance&uid=4104
Mark- Top
David:
That is a great looking lift for $1800. Who is the mfg? At that price, it is hard to not have one in the shop.NCRS New England Chapter Chairman 2022, 2024
N E Regional Chairman 2024
1967 Corvette Convertible Under Restoration
1996 Corvette Coupe NCRS Chapter Top Flight 99.5, NCRS National Top Flight 100.0- Top
The rule of thumb I use is a disassembled car takes up 5 times as much space as one put together. It can be done in a two car garage. My suggestion is to build some floor to ceiling shelves the full depth of the garage to hold everything.- Top
Yeah I bought all new shelving units and and they pretty much line all available wall space... Based on the space a 4 post lift will take (I'd have to squeeze around the posts, I'm now thinking of building a dolly to put over the chassis and raise the body up 4 feet -- but I'm still kind of brainstorming.- Top
Thomas,
It is a Direct lift. Link below:
67 Corvette 327/350
60 190SL Mercedes
70 280SE Mercedes Cabriolet
07 ML350- Top
Here's what my car looks like with its body off in my two car -- very full -- garage, for anyone who's interested.
It was a lot harder than I thought it would be reading all the posts :P But aside from some stress, it was good times. Thanks to Mark pellowski for helping me out
- Top
Nice work. See you worked out the saw horses...where did you pick up the metal stands for the saw horseHere's what my car looks like with its body off in my two car -- very full -- garage, for anyone who's interested.
Tom Russo
Wow ! Well done Ian and Mark. I bet it feels good to finally be able to see and get at the task at hand.
Ian can you push the chassis out of the garage to work on the chassis outside, weather permitting.
Stewy- Top
Ian,
Very, very cool! You have given me hope that I can do a frame off restoration in my very small two car garage (18x18x8). What are the dimensions of your garage? How do you plan to store the body while you work on the frame and vice versa?
Joe- Top
- Top
NAIL
HEAD
We had a real hard time getting the body oriented correctly. I'd really like to know what is meant by "mounting position for the trunk/rear hatch"? That's supposed to be the rear mounting spot, but Mark and I couldn't figure out where to connect bolts and clips there, aside from hanging it from the hinge itself and that didn't seem like a good idea, so I used the convertible top bracket. This made the car dip in the back, so we ended up using about four 4x4 stacked on top of each other to lift the back balanced on the rear crossmember to get it straightened out enough. We enlisted a couple friends to help, so it was a mixture of lift party/cherry picker method...- Top
With hindsight we should have used a strap for the rear and a strap for the front rather than a strap for the driver side and a strap for the passenger side.
We should have also used an engine leveler. We would have then had very good control of the body position.
It was learning experience for sure and satisfying.- Top
