091 coil - NCRS Discussion Boards
091 coil
  • Richard B.
    • May 31, 1984
    • 32
    091 coil
    I stripped the paint of what i thought was an original coil and found 235 br stamped in to the side could someone please tell me what it means because 091 is stamped into the other side down low
  • William C.
    • May 31, 1975
    • 6037
    Re: 091 coil
    It means the last three numbers in the actual part number for the coil were 235 or whatever, not 091
    Bill Clupper #618
    • John D.
      • December 1, 1979
      • 5507
      Re: 091 coil
      Richard, Where did you get that coil? John
      • Richard B.
        • May 31, 1984
        • 32
        Re: 091 coil
        i bought it a swap meet
        • Mike E.
          • February 28, 1975
          • 5134
          Re: 091 coil
          Can you say "reproduction?"
          • Dave S.
            • August 31, 1992
            • 2918
            Re: 091 coil
            Richie,
            I'm not sure I understand what you mean. Is there two sets of embossed numbers.??? Did someone braze an 091 tag onto a 235 coil. ??? Lots of creative restorers out there.
            • Harry S.
              • July 31, 2002
              • 5258
              Re: 091 coil
              Can you post some pictures?
              • Bruce B.
                • May 31, 1996
                • 2930
                Re: 091 coil
                Is the 091 stamped into the coil surface or raised on the surface like a correct coil?
                • Richard B.
                  • May 31, 1984
                  • 32
                  Re: 091 coil
                  The 091 is raised from the inside out the top pad is raised with the holes the 235 br looks like it was stamped
                  • Mike M.
                    • May 31, 1974
                    • 8365
                    Re: 091 coil
                    you state in your original post that you stripped the paint off the coils exterior. what color is the metal? Copper? Cold steel? early repo cans( with 091 embossed in their metal )to slip over a non-091 coil were copper composition. mike
                    • John D.
                      • December 1, 1979
                      • 5507
                      Re: 091 coil
                      Richard, Did you buy it at Carlisle?
                      • Rick A.
                        • July 31, 2002
                        • 2147
                        Re: 091 coil
                        was gonna say, sounds like a GOAT HILL special!
                        Rick Aleshire
                        2016 Ebony C7R Z06 "ROSA"
