I rebuilt my 69 Corvette's 350/350HP into a 383 stroker.
The motor clearly had been rebuilt before as all of the internals look very good. The Crank is the Hi-PO and has been magnafluxed with stock specs. it has the painted Pink Rods etc.
My question is, is this worth selling as a complete rotating assembly +, or is it just worth selling the bigger ticket items like the Crank and Rods.
I have:
Oil Pump
Timing Gear
Timing Chain
Cam
Lifters
Tappets
Rods
Pistons
Balancer
Hi-Po Crank
Pretty much all of the internals. Just wondering what's the best approach whether selling all together, or seperating some or all.
Also, any recommended minimum reserve I should set is appreciated.
I have:
Oil Pump
Timing Gear
Timing Chain
Cam
Lifters
Tappets
Rods
Pistons
Balancer
Hi-Po Crank
