396 Fan blade - NCRS Discussion Boards
396 Fan blade
  • Donald S.
    • January 23, 2008
    • 183
    396 Fan blade
    Can some one please post a pic of the front and rear of a known origional 65 396 fan blade I know they are out there but in all my searching i have not found an origional one . thanks for your help Don....
    Re: 396 Fan blade
    Posting a picture isn't going to help you much... The difference between the 396 BB fan and the standard SB fan is SO slight, they're almost impossible to tell apart unless you REALLY know what you're doing!
    There's an overall diameter difference of 1/8-inch (good luck in measuring/verifying that!) and something like 3-degrees of pitch differential in the blades.
    If you want/need a 'correct' 396 fan, then my suggestion is to go buy the reproduction from Paragon. It was tooled using a 'loaner' from long time NCRS 396 expert, Charlie Stewart, now deceased....
    • Keith B.
      • December 1, 1991
      • 397
      Re: 396 Fan blade
      Here is a thread from a previous discussion
      https://www.forums.ncrs.org/showthre...61156&uid=7947
      Keith Burmeister
      • Donald S.
        • January 23, 2008
        • 183
        Re: 396 Fan blade
        thanks guys i now have the pics i need to help inform my decision Don....
