AFB Throttle Shaft Bushing kit? - NCRS Discussion Boards
  • Jeff B.
    • November 6, 2008
    • 154
    I'm rebuilding the AFB Carburetor from my 1964 327/300hp and I found that both the primary and secondary throttle shafts have significant movement in the carb body. I'm sure it's enought to create a vacuum leak. There does not appear to be factory installed bushings in the body, it looks like the aluminum body was just machined to fit the shafts. I can't find a repair / bushing retrofit kit for this carb like those listed for Holley's and Quadrajets. Anybody know what will work for the AFB. I'm sure Holley's custom shop would take care of it but I'm enjoying doing it myself. My carb is a 3721, with body number 0-1552.
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: AFB Throttle Shaft Bushing kit?
    i have heard that holley also has closed its doors plus a email i sent to my contact at holley was never answered. holley shafts are .368 dia and the bore is .375 so there is about .007 clearance
    • Timothy B.
      • April 30, 1983
      • 5177
      Jeff, If you do a google search there is a supplier that has the special tools and makes a kit.. From reading, I think McMaster carr has the thin bronze bushings.
      I can't offer any more than this because I never purchased the kit. I am scared to mess up a vintage carburetor.
      • Clem Z.
        • January 1, 2006
        • 9427
        any auto machine shop that does split bronze valve guide work will have the bushing material
        • Stuart F.
          • August 31, 1996
          • 4676
          If you are able to find such a kit, be sure to post the information on the TDB. Also, make sure it has instructions and that you follow them closely, beginning with how to take the throttle plates out.
          BTW, the 3721S (A & B) are plentiful at reasonable costs (I have two myself, incl. one spare) compared to say the 3461S for a 63. If your 64 was a late year build, most any date preceding your build date should be fine. There are plenty that were built after 64 as it was the service replacement for 63 - 65 until production ceased. My main carb is dated "E9" (1969 or 1979??).
          Stu Fox
