rear exhaust L shape bracket position - NCRS Discussion Boards
  • Jim H.
    • April 1, 2002
    • 112
    I now noticed another difference using a 60 frame is the rear exhaust hangers are in a different position than on a 61/62. Does anyone know the position where the holes which mount onto the side rail on the frame are suppose to be located?
    I think I might be able to figure out the position if I had the exhaust and the engine mounted on the front.
  • William C.
    • May 31, 1975
    • 6037
    Re: rear exhaust L shape bracket position
    The attached picture is taken from behind the rear tire, but I think you should be able to get a pretty good idea of the arraingement. I'd setup the exhaust pipes and then locate the rear "L" bracket in a position that provides best clearance where the pipe comes thru between the body and frame.
    Bill Clupper #618
