How many pounds for the pump bolt? Small block
Oil pump bolt torque
Tags: None
Re: Oil pump bolt torque
Clem,
If Mike is talking about his '55, then it uses the long bolt. Using the short bolt where a long bolt is specified can cause insufficient clamping forces and the bolt can back out.
Not sure when the main cap was changed, but those with the depression around the bolt must use the short bolt. Using the long bolt in instances which specify the short one will lead to the situation which you mention.- Top
clem-----
If one needs one, these bolts might be hard-to-find these days. The GM bolts, both the 55-62 as well as the 63+ are GM-discontinued. I don't know of an aftermarket replacement for them but there may be one.In Appreciation of John Hinckley- Top
clem-----
The 55-62 bolt was 2-3/16" long. the 63+ bolt was 2" long.
Many of the oil pump studs have only a limited length of the 7/16-14 threads. They will not thread in far enough to contact the bearing shell.In Appreciation of John Hinckley- Top
the studs i ran into that could be threaded in too far were the moroso set up that used a extruded aluminum extension to lower the pump into the deep sump pans so the pump pick up tube did not have to be lengthened. http://www.eautoworks.com/product-Mo...nce-240814.htm- Top
