C1 heater motor - NCRS Discussion Boards
C1 heater motor
  • Roy B.
    • February 1, 1975
    • 7044
    C1 heater motor
    Some one a while back did a great article on replacing the rear bearing. But I wont to let people know that now and then on e-bay under the word (Delco heater motor) you can find a new one . Corvette used ONE HOT brown wire for the motor which came out at the front area " so look at the pic" (not the back area) like the car having three wires . One wire was used because the speed control was at the heater switch not at the motor like car.
    If your lucky a seller may post one not using the word CORVTTE saving you hundreds of dollars. Good luck.
    These are a few I got on e-bay over the years.
  • Bill B.
    • December 1, 1993
    • 192
    Re: C1 heater motor
    Roy - Yes, I have seen those motors occasionally on ebay but having trouble finding a squirrel cage for my 61. I have a 64 motor picked it up real cheep late night from ebay. This should work the motors and mounting are the same up to 65 correct? I appreciate it
    Bill
    1961 Black/Silver/Red Int. 283/315 FI
    power windows. Frame off 65% completed.
    1989 hard top daily driver 165,000 miles
    • Roy B.
      • February 1, 1975
      • 7044
      Re: C1 heater motor
      C2 heater motors I'm not that informed , but a C1 squirrel cage would be the same as early Chevy car, I remember using one from a car but cant remember which years. Sorry I cant be more help.
      • Bill B.
        • December 1, 1993
        • 192
        Re: C1 heater motor
        Ok Roy, will look elsewhere. Appreciate your quick reply.
        Bill
