I have several questions in this area:
1. What is the correct finish of the center plate? ----- I believe it to be semi gloss black?
2. Is the finish on the (4) mounting bolts black oxide or black phosphate?
3. The (4) bolts that I have are just a shade under 3.25 long (under the head) --- is this OK for a standard 9 leaf spring? or should it be a bit longer for better engagement?--- Not sure if this spring is original or not ?? --- it has traces of the light grey primer on the end faces and the ends are curled up.
Thank you very much for your help,
Ralph
Ralph
