Radiator 68 427/435 Question - NCRS Discussion Boards
  • Pererik F.
    • November 30, 2006
    • 7
    NEED YOUR ASSISTANCE/EXPERTISE HELP
    HAVE RESTORED MY EARLY 68 AND HAVE A QUESTION ON DETERMINE IF THIS IS THE RIGHT RADIATOR FOR MY CAR
    THIS IS THE ONE THAT WAS IN THE CAR WHEN I BOUGHT IT
    MEASUREMENTS ON THE CORE IS 22.5 x 17
    IT HAS ONE TAG THAT SAYS AM 66 1
    I HAVE POSTED SOME THUMB.JPG AT THE BOTTOM
    BUT I CAN SEND FULL PICTURES FOR BETTER VIEWING
    ERIK
  • Jack C.
    • September 30, 1992
    • 1090
    Re: Radiator 68 427/435 Question
    On my orignal early 68 #9643, there was only the metal tag clipped to the passanger side which read MK. My 400 and your 435 should have the same radiator according to TIMJG. I saw no date stamping.
    Jack Corso
    1972 Elkhart Green LT-1 Coupe 43,200 miles
    Top Flight 1994, 2018 & 2021
    • Dick W.
      • 10483
      I believe the core measurements should be 26.5" or 27.5" on center. Do not have manual here to confirm.
      Dick Whittington
      • John C.
        • January 1, 2005
        • 616
        Erik
        It is not the correct radiator for a 68. In the pictures you show and end tank that has a curved inlet. It should have an inlet pipe that comes straight out and then turns 90 degree with be a mitered connection with a second pipe. Dewitt's website shows some excellent pictures of what it should look like. Check it out
        John
