Hello
I am just finishing the drive train on my 69 SB M21 restoration but am having some trouble with the main drive shaft. I purchased a replacement shaft with universal joints because the original was very severely rusted. When I went to install the shaft yesterday it seems that it is too long? I checked it against he original and it is the same. The shaft can be installed if I pull the caps off and wrangle it into the rear end yoke and then put the bearing cups on. My concern is that with this so close on the length will the present any issues with bind or bumping into the tail stock? And since this seems to be the same as the original that I took out so long ago that I cant remember what the install was like could there be another issue going on here? The motor and Trans mount dropped right in easy as can be and seems to line up perfectly.
Thanks in advance for any help.
