C-1 Upper Inner pivot shaft restoration - NCRS Discussion Boards
  • Keith R.
    • August 31, 2001
    • 660
    Have researched the archives and found repeated recommendations NOT to remove the upper inner pivot shaft due to the difficulty involved and the possibility of cross-threading. Right now, my upper A arm is attached to the crossmember by the inner shaft and bushings and I'm trying to figure out how to clean, replace the seals and repaint without pulling out the shaft. One archive post said that the A-arm could be removed by removing the bushings and leaving the shaft in place. Also, a fellow chapter member said that once restored, the A-arms should fall freely to the crossmember and my unrestored arms are pretty tight right now and do not fall freely. Is this correct? Sorry for the long post but would welcome any comments. Thanks all.
    Keith MacRae
    NCRS #36692
    New Mexico Chapter
    1960 290HP FI
    2013 427 Convertible
    Shade tree mechanic and
    B-52 pilot extraordinaire
  • Reed F.
    • May 31, 1996
    • 31
    Re: C-1 Upper Inner pivot shaft restoration
    With apologies to the purists, take a look at this post on CF, it is helpful if you've never done a C1 front end.
    Reed
    http://forums.corvetteforum.com/c1-a...build-of-53-62
    • Keith R.
      • August 31, 2001
      • 660
      Thanks Reed however the link doesn't appear to work.
      Keith MacRae
      NCRS #36692
      New Mexico Chapter
      1960 290HP FI
