1965 300hp with powerglide - NCRS Discussion Boards
  • William G.
    • April 1, 1978
    • 154
    on the automatic shifter do the wires on the backup switch asm all go through the dash to the engine compartment
    4 wires-- 2 purple wires 1 green and
    1 brown or gray and connect
  • Jeff S.
    • July 31, 1984
    • 383
    Re: 1965 300hp with powerglide
    Only the 12 Ga. purples go through to the engine bay. The 18 Ga pair stays inside, arcs over the pedal brace and steering column assy, then connects to a two-conductor/90* female connector with an 18 pink & 18 lt. green. Mine ('66) makes this connection kind of near the parking brake shaft.
      Bill -
      See section M35, sheets 5 and 6 in the 1965 Assembly Manual - shows all the routing, taping, connections, etc.
      • William G.
        • April 1, 1978
        • 154
        i guess i will hae to invest in a 1965 assembly manual.
        i have been trying to work off a 1967 assembly manual.
        thanks for the reply jeff and john
        bill
        • Jeff S.
          • July 31, 1984
          • 383
          Bill
          I believe there were two NSS's used in '65; a two-wire version for cars w/o the backup light option, and a four-wire version for cars with backup lights. I don't recall the part numbers, but they'd be in the '65 AIM. In '66 + '67, backup lights became standard equipment (not an option) and all switches were four-wire.
          I have an NOS '66-'67 switch (#1993411) that is four wire. According to the parts book, this is service replacement for '65-'67. Since your original thread stated backup lights, I would think that the '67 AIM instructions would suffice.
          Jeff
          • William G.
            • April 1, 1978
            • 154
            jeff
            engine harness i know you use the purple wires
            then i have green and a gray wire could be brown i did not
            look today.
            on the harness (MAIN) i have black green and a black pink
            dont know if they go to the green and gray
            but i saw a buddy tonight and he said he had a
            1965 assembly manual so should be able to get it straighten out
            for some reason i cant seem to get it in my head where it goes
