Re: Carter carbureator
John,
The 350hp cam with 15" idle vacuum at 750RPM is excellent, the best I could do with a L-79 cam is 14". I am surprised the cranking pressure is 160 with flat top pistons, are you sure about the cam that's used.
That being said, try to increase the inital timing to 10-12* for a test. The engine will idle even better and should make more vacuum.
My thought is that when the throttle blades are opened like after the clutch is out, the engine goes under load and vacuum drops, the fuel drops out of the emulsion in the manifold and creates a lean condition. The accelerator pump is there to cover this transistion with a good shot of raw fuel at just the right time. I am not sure the nozzle size (diameter)but on Holleys this can be changed for more fuel initally.
I guess the first thing is to make sure the pump is working and adjusted properly. That includes the check valve in the float chamber and the check valve (needle seat) under the shooter to keep air and vacuum from sucking fuel.
I would think the idle jet at .038 would be large enough so A/F ratio is probably good. Make sure the rubber vacuum line at the vacuum advance is not egged causing a leak.
John,
