1969 Exhaust Tip Exit Length? - NCRS Discussion Boards
  • Steven H.
    • June 29, 2009
    • 137
    How far should the tips stick out, are they straight out or do they have an angle, or is there a GM installation sheet?
    Steve
    Re: 1969 Exhaust Tip Exit Length?
    Steve
    Steve----
    I have never found a GM spec for the "protrusion" of the exhaust tips for 68-69. I don't even know if it was precisely accomplished on the assembly line. However, I believe the intention was that the inner end of the exhaust extension (i.e. "tip") was to be coincident with the inner end of the "straight section" of the muffler's outlet pipe. Consequently, I think the correct dimension is about 3-1/4-3-1/2" measured from the top of the bezel to the top end of the extension.
    The extensions were NOT angled, either vertically or laterally.
    • Steven H.
      • June 29, 2009
      • 137
      This advice is taken and will be used for install, thank you!
      • Jack C.
        • September 30, 1992
        • 1090
        I always thought that the top of the tip should be at the trailing edge of the bumper.
        Jack Corso
        1972 Elkhart Green LT-1 Coupe 43,200 miles
        Top Flight 1994, 2018 & 2021
        • Terry B.
          • August 31, 1999
          • 607
          That is an interesting question, Steve. I went out to measure my '68's and found that my exhaust tips are about 4" out from the top of the exhaust bezel to the longer tapered side of the exhaust end. I would think they should not stick out beyond the bumper for sure. At 4", they are about an inch or so inside the bumper. It looks good to me but 4" might be the maximun that I would have it extend.
          Terry Buchanan
          Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
          Corvettes Owned:
          1977 Coupe
          1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
          2003 Electron Blue Coupe
          2019 Torch Red Grand Sport Coupe
