Problem of short running time 10-15 sec. after rebuild solved - NCRS Discussion Boards
  • David N.
    • June 30, 1991
    • 142
    I recently asked for advice on an ignition problem with our '69 427 after rebuilding it. Upon further investigation when checking a wiring diagram for a Jacobs ignition system I discovered that I had failed to ground a wire. Once grounded, problem solved. Thanks for all replys to previous post.
    David
