60 Heater hose connections at engine - NCRS Discussion Boards
  • Greg L.
    • March 1, 2006
    • 2291
    I'm trying to hook up the heater hoses but can't figure out what to do with the water pump connection. As you can see the gen adjusting bracket will interfere with a fitting so what is wrong here? Is the pump wrong or is the adjustment brace in the wrong place.
    Sorry for the noob question but I'm still pretty green on these cars.
  • Jim D.
    • 2882
    Re: 60 Heater hose connections at engine
    Greg,
    You need the correct mounting stud that moves the brace forward. http://www.parts123.com/parts123/yb....Z5Z5Z50000050x Be sure to use the correct curved water pump fitting as well.
    • Greg L.
      • March 1, 2006
      • 2291
      Thanks Jim.
