66 grill - NCRS Discussion Boards
66 grill
  • Harry L.
    • December 22, 2008
    • 370
    66 grill
    does anyone have location or pictures of the casting number of the 66 corvette grill? thanks for any replies ! DUTCH
  • Kenneth F.
    • September 30, 1988
    • 282
    Re: 66 grill
    Hi Dutch, The grill is not easy to examine while in the car. I could not see any numbers. Should you find otherwise, I will look again.
    Ken
    • Wayne M.
      • March 1, 1980
      • 6414
      Re: 66 grill
      Agree with Ken; very difficult to completely examine while in the car. Nevertheless, got out my light and mirror and ran my fingers over just about the entire surface, and could not see a casting symbol or number.
      However this grille was installed about 1970, so it's a service unit for '65-7. Still, I'd expect to see something .
      • Mike M.
        Director Region V
        • August 31, 1994
        • 1463
        Re: 66 grill
        Hi Dutch
        Looks like I need to go public with the information I provided to you in the PM you requested.
        Yes, the '66-7 grills have a "unique" part number 3875746 about 1/8" in height cast into the inside of the top bar just off center to the passenger side.
        It can be located with a mirror while the grill is in place on the car.
        HaND
        • Wayne M.
          • March 1, 1980
          • 6414
          Re: 66 grill
          Originally posted by Mike Murray (25129)
          ....Yes, the '66-7 grills have a "unique" part number 3875746 about 1/8" in height cast into the inside of the top bar just off center to the passenger side.
          It can be located with a mirror while the grill is in place on the car. ...
          Mike -- Found it ! But not at the location you described [maybe it's like that pesky '65 grille "D & L" stamping that is found at random locations].
          Mine's on the BOTTOM surround, inside lip, and about 1.5 inches to the DRIVER side of the bottom cast center bracket, which you can see on the right edge of 1st the photo.
          2 pics below: first shows the cast # upside down; you can see the licence plate and mounting bracket in the background. 2nd pic, I flipped it 180 degrees to read the detail on the cast #; is the last digit a '6' flipped backwards ?
          • Mike M.
            Director Region V
            • August 31, 1994
            • 1463
            Re: 66 grill
            Good Job, Wayne.
            By stating the "Unique Number", I was wondering if anyone would catch the backwards "6"
            HaND
            • Harry L.
              • December 22, 2008
              • 370
              Re: 66 grill
              Mike, thanks for the pictures. I'm still looking. Is it on the inside lip of the top chrome ledge,. about how far over from the middle holding tab. Can you take a picture of the whole grill and point to the spot? thanks, MIKE . SOME TIMES I need a little more direction . DUTCH
              • Jim C.
                • April 1, 2006
                • 290
                Re: 66 grill
                One of my favorite things about this hobby is "looking for the numbers." I never knew the 1966 grille had a part number on it. BUT I FOUND IT!! Pretty cool. Wayne M., mine was exactly where you said it would be, on the lower horizontal bottom edge behind the lip, just a little to the driver's side of center. 3875746. Nice. I checked an older version of the JM and it doesn't list any part number for the grille. Thanks for the info. Keep the trivial details coming!!
                Jim C.
                • Harry L.
                  • December 22, 2008
                  • 370
                  Re: 66 grill
                  Well I just found my grill casting number on the lower surround lip to the right of the center. Oh happy findings! I have to learn how to post pictures, because I have many numbers to share and compare. Thanks for all the interest. DUTCH
                  • Patrick T.
                    • September 30, 1999
                    • 1286
                    Re: 66 grill
                    If anyone needs a new '66-'67 grill they are still in production.
                    http://www.gmpartsdirect.com/restora...tocategory.cfm
                    0 items in cart
                    check out your
                    wish list
                    order
                    status
                    your
                    account
                    SEARCH Advanced Search FAQ View Cart Register Request a Return Customer Service GM Warranty E-Mail Us Tell a Friend Home
                    Search Results of Available Restoration Parts GM PART # 3875746
                    PACK QTY: 1 CORE CHARGE: $0.00
                    GM LIST: $642.54
                    OUR PRICE: $394.26
                    DESCRIPTION: RADIATOR GRILLE
