C2 door locks - NCRS Discussion Boards
C2 door locks
  • Randy S.
    • January 1, 2003
    • 586
    C2 door locks
    The door locks on my 66 convertible rotate when I try to lock the doors. When I did this repair a number of years ago (obviously not correctly) I don't remember anything that kept the lock cylinder from rotating other than pressure from the clip on the inside against a rubber washer behind the lock cylinder.
    Did I miss something? Any tips?
  • Gary B.
    • February 1, 1997
    • 6979
    C2 door locks
    Randy,
    You are correct. There is no geometric keyway in the fiberglass to orient the lock. It relies on friction/compression via the retaining clip on the backside.
    Gary
