69 L46 Radiator Hoses - NCRS Discussion Boards
  • Gary V.
    • May 6, 2009
    • 20
    My TIM&JG hasn't arrived yet. Can someone tell me the correct GM #'s for the upper and lower radiator hoses for a:
    1969 350/350 L46, standard transmission, COPPER radiator, no A/C, no P/S. October 69 build if that makes a difference.
    I'm pretty sure the upper hose is 3946852, but I'm not seeing in all of my various vendor catalogs a listing for the lower hose that makes sense.
    • Corvette Central shows a 3946854 for a 350 with Auto and/or AC, LT1
    • Paragon shows the 3946854 as small block with Auto, 4 speed with AC,. Copper radiator.
    • Doc Rebuild shows the 3946854 as Factory Equipped with a Copper Radiator, with Auto and/or AC.
    • Corvette Central shows a 3917669 for a 350 with 4 speed, no AC, ALUMINUM radiator
    • Paragon show the 3917669 as all with aluminum radiator or copper REPLACEMENT exc Special Hi Perf, AC or Turbo Hyrdamatic.
    So, from these references, I don't see a hose for my car. What am I missing here ? What does the TIM&JG show for the correct hoses ?
    Thanks in advance
    Viz
  • David S.
    • August 9, 2009
    • 595
    Re: 69 L46 Radiator Hoses
    As per the 69 Judging Manual. 350 with Copper -
    Upper - 3946852
    Lower - 3946854
    -Dave
    • Gary V.
      • May 6, 2009
      • 20
      Upper - 3946852
      Lower - 3946854
      -Dave
      Thanks Dave. So it doesn't differentiate for Auto, or AC ?
      Viz
      • David S.
        • August 9, 2009
        • 595
        Also for your reference, below is a picture of the chart on page 65.
        -Dave
        • Gary V.
          • May 6, 2009
          • 20
          OK, that's perfect !! Thanks again Dave, appreciate the info and quick responses !
          Viz
          • David S.
            • August 9, 2009
            • 595
            Happy to help!
            -Dave
              Viz
              Gary-----
              For 1969, any small block application that was equipped with automatic trans AND/OR air conditioning used the copper/brass radiator. Some mostly later L-46 without air conditioning (no L-46 had automatic trans) also used the copper brass radiator. The radiator hoses used with the copper/brass radiator were unique to Corvettes equipped with that radiator.
              • Steven H.
                • June 29, 2009
                • 137
                This may be very helpful to me this weekend as I just dropped the rad assembly in last night.
                Thank you.
