Power Steering Pump Finish - NCRS Discussion Boards
  • Sheldon S.
    • March 1, 1999
    • 474
    Several questions regarding the power steering pump for a 71 BB.
    1- Was the pump painted as a complete unit including the two studs and the large flow valve nut on the back side of the resovoir?
    2- The gloss of the black on the pump-?
    3- The thin nut that holds the pulley on- what kind of finish?
    4- Was the pulley painted the same as the pump?
    Sheldon
    Re: Power Steering Pump Finish
    Sheldon
    Sheldon----
    1) The pump was painted as a complete unit including the studs and nut on the back of the reservoir. However, a plastic cap was place over the return nipple. So, the last inch, or so, of the nipple is unpainted. Not that it matters-----the hose covers this area, anyway;
    2) The pumps were painted a semi-gloss black, tending to the "flatter" side of "semi-gloss";
    3) The special lock nut for the pulley was DULL SILVER zinc or cadmium;
    4) Big blocks used a 2 groove cast iron pump pulley. I just don't recall if this pulley was natural cast iron or semi-flat black (perhaps from the same phosphating process used for the big block crank pulley that we recently discussed).
