What color is the torque convertor supposed to be on early production air cooled powerglides? What information is on the 1963 powerglide dipstick?
1963 Air cooled powerglide
Re: 1963 Air cooled powerglide
Arthur, See page 139 of the 5th edition for dipstick.
"The flat steel loop dip stick handle and skirt have a natural unpainted steel finish."
I can see why you asked though as no desciption is provided.
Read page 138 and 139. JD- Top
Thank's John. The reason I was asking is that, I was advised the transmission dipstick changed in 1966 and the information for proper service is different on the 1963 to 1965 dipstick. Also since the air cooled transmissions has four large holes for cooling, you can see the torque convertor heat shield. I can't find any reference material that advises the correct original color of the convertor.- Top
Thanks Cecil.The 3rd addition teck manual, page 146, advises that early production 1963 vettes, up to vin 6500 do not have transmission fluid coolers. The air cooled case is also pictured in the 63 shop maual.- Top
Admittedly, my copy of Nolands book is a first edition so I don't have any revisions.
Anyone else have an original early 63 M35 with air cooling holes so I can stand corrected ?- Top
And speaking of holes..... the early PG cars take a radiator support that does NOT have the hole for the hoses for the cooler. Relatedly, the shroud for these early cars is made without a clearance notch for the hoses that aren't there.
Jim- Top
Hope this helps.
JimAttached Files- Top
