Hi all;
I'm still cleaning up things from my (failed) PV attempt at Marlborough... I need to tighten up the main window regulators on my 1965... What is the conventional wisdom for this? Are these repairable or should they be replaced? If replacement is in order, who is a good source? If they are repairable, I would prefer to try and do this myself if possible...
I had the same problem with the vent window regulators... Bought two repops prior to the regional which were in a word, JUNK.. Wound up getting two reconditioned units from Mike at AFC which are super.... Don't want to make the same mistake on the main regulators.
Thanks!
Joel
Thanks!
Joel
